  3. Sonstiges
  4. Audi-Galerie
TT RS: Headed For a Geneva Debut.
  • I'm Gone.
  • 28. November 2008 um 00:08
  • I'm Gone.
    The Audi TT RS is said to arrive at the Geneva Motor Show, we have an outlook.
    Audi gives its sporty little TT a high five (cylinder).
    Five-cylinder engines have long been an Audi trademark.
    First used in 1977 in the Audi 100/5000, five-cylinders took Audi upmarket and clearly differentiated the brand from the competition.
    The Audi 200 Turbo, with its 170-hp inline-five, became the world's fastest four-door in 1984; the 315-hp, Audi 80–based RS2 Avant of the mid-‘90s was the most extreme station wagon of its time; and Audi won several rally championships with the five-banger Quattro—the S1 Pikes Peak had almost 600 hp.
    In the mid-‘90s, Audi dropped the five-cylinder engine and its characteristic, subdued growl in favor of more conventional four-cylinder and V-6 engines.
    Brand aficionados howled in futile protest, and engineering guru Ferdinand Piëch, who had developed the five-cylinder engine but later moved on to become head of VW, said he never quite understood why the engine had been dropped.
    It’s Back!
    As of March 2009, a five-cylinder will be back in Audi's range in the form of a 2.5-liter unit with direct injection; it is based on Audi's modular engine architecture.
    The transversely mounted engine is force-fed by a single turbocharger and will make 330–340 hp.
    Torque is rumored to be around 330 lb-ft.
    That's enough to significantly set the TT RS apart from the lesser TTS with its 265-hp, 2.0-liter TFSI four-cylinder engine.
    The TTS coupe is claimed to run from 0 to 60 mph in 4.9 seconds, and the fixed-roof TT RS—which will be built as either a 2+2 coupe or roadster—should jet to 60 at least a half a second quicker.
    If customers request it, top speed will be raised to 174 mph; the TTS is governed to 155.
    Curb weight will be around 3000 lb and Quattro all-wheel drive will be standard.
    Power will be transmitted through a six-speed manual transmission; it is unlikely that the dual-clutch transmission will be adapted to the TT RS.
    Expect minor but significant changes to set the TT RS apart from the TTS. It needs even more air, so the front intakes will be larger, and it will sport the two large oval exhaust tips which identify Audi's RS models.
    Just a few months back, a tussle strained Audi and Porsche's high-tension relationship even further: Porsche threatened to take legal action against Audi's use of the RS moniker.
    Porsche had long ago managed to protect the RS nameplate for its exclusive use and allowed Audi to use it only in conjunction with a number, as on the RS 4, RS 6, and so on. Audi engineers went ballistic, and Porsche backpedaled, allowing the TT RS to keep its name.
    Listen for a five-cylinder rumble at the 2009 Geneva auto show next March, which is where the TT RS is scheduled to make its first public appearance
  • Cossor
    • 28. November 2008 um 00:57
    Ich halte das für ein Fake.
    Einige Angaben sind nicht korrekt (TTS z. B. 265 hp) und der TTRS soll erst im August 2009 kommen…und nicht schon im März! Im März 09 wird ja der S4 lieferbar sein.
    Das mit der Beschleunigung könnte hinkommen…über den Heckflügel wurde wieder nichts gesagt…
    …und wenn der TTRS mit ebenfalls nur einem Turbo kommt, wird ja wohl mindestens ein so großes Turboloch sein, wie im TTS – was ja einige Leute stört...
    Sorry, ich bleibe weiterhin skeptisch bis etwas Offizielles von Audi kommt…
    Audi TTS Roadster S-tronic, MJ09 - EZ: 21.11.2008
  • Lucutus
    • 28. November 2008 um 08:48
    Er wird aber im März der Öffentlichkeit vorgestellt. Das heißt noch lange nicht, dass man ihn dann auch kaufen kann.
    Ist genau das selbe wie beim S4, der wurde auch schon vorgestellt, aber ist noch nicht zu kaufen.
  • ses
    • 28. November 2008 um 09:26
    ich würds cool finden, wenn die RS-Rückleuchten auch ein LED-Band hätten ... die würde ich beim TTS dann nachrüsten, die aktullen find ich bissel langweilig.
    Audi A1 Forum & Community - A1talk.de :!:
  • Cossor
    • 28. November 2008 um 11:18
    Die Beschleunigung vom TTS auf 100 km/h stimmt ja auch rein gar nicht!
    Sorry, wenn die beschleunigungswerte eines Wagens, der schon Monate produziert wird nicht stimmen, sowie die PS-Angabe, liegt da was im Argen!
  • Hampi
    • 28. November 2008 um 11:44
    Beschleunigung ist halt von 0-96 Km/h (0-60 mph).
  • Cossor
    • 28. November 2008 um 12:27
    Zitat
    Original von Hampi
    Das ist mir schon klar, dass eine Meile ca. 1,61 km sind!
    Nur braucht das TTS QP 5.4 Sekunden, bzw. 5.2 Sekunden mit S-tronic.
    Ich kann mir beim besten Willen nicht vorstellen, dass der Wagen dann auf 96,6 km/h 0,5 bis 0,3 Sekunden schneller sein soll...
  • Hampi
    • 28. November 2008 um 12:41
    ...bis echte 100 km/h muss er halt noch einmal Schalten :D :D ;) !
  • Athos1
    • 28. November 2008 um 13:56
    hoffen wir das beste je eher der vorgestellt wird desto besser und je eher ich den bestellen kann auch..... unbedingt haben will.
  • MartinB
    • 29. November 2008 um 12:28
    Zitat
    Original von Cossor
    Also darauf würde ich jetzt nicht zu viel geben:
    Der Artikel war auf englisch, bezieht sich also nicht zwangsläufig auf die deutsche/europäische Version des TTS/TTRS.
    Zum einen habe ich mal gelesen, daß die "hp" nicht überall den "PS" in Deutschland entsprechen und zum anderen hat das selbe Modell in anderen Ländern evtl. auch unterschiedliche Leistungsdaten (z.B. wegen anderen Abgasvorschriften).
    Mein letztes Auto hatte z.B. in DE 140 PS und in der US-version 139 hp...
    Grüsse, Martin
    (TTS Roadster - S-tronic - Aussen: tiefseeblau - Innen: schwarz/silber - Bremsen: quietschend)
  • SOttle
    Board-Elite
    • 29. November 2008 um 18:58
    Wo genau wird der RS vorgestellt?!
    EDIT: Habs überlesen! Genf.
    Grüßle Tobi
    Einmal editiert, zuletzt von SOttle (29. November 2008 um 18:59)
  • Athos1
    • 1. Dezember 2008 um 10:54
    Mal abwarten , ob es tatsächlich so sein wird......... wenn der TT RS eine hässliche Frittentheke ab Werk bekommt, bleibt mir nur noch die Hoffnung, dass an den Gerüchten dass ein Audi R4 mit Mittelmotor kommen soll etwas dran ist.
    Einmal editiert, zuletzt von Athos1 (1. Dezember 2008 um 10:56)
  • Athos1
    • 13. Dezember 2008 um 19:39
    Soll eigentlich der RS Roadster zugleich mit dem RS Coupe präsentiert werden ????Weiß jemand schon mehr von seinem Freundlichen
