internal detail
-center side dashboard : turbo pressure gauge
-right side dashboard : exhaust gauge temperature
-lower side dashboard : boost controller
first test ..... good peak turbo pressure
internal detail
this is a normal TTS/sline front bumper with front spoilerlippe
other photo of the spoilerlippe mounted on bumper.
other photo....
front spoilerlippe
modification to stock airbox
photo of big turbo kit (mounted on TTs friend's ; 1 mounth and the same kit turbo is mounted on my TTs)
rear brake disk 356x32 + 4 pot caliper
turbo arrived today
tell me what detail other photo did you want and i will do it ![]()
starting with a new project for my TTs
Inox tubolar manifold + big turbo for 2.0 TFSI
stay Tuned
Hi guys ; i need to know one information:
I have mounted on my TTS stage 2+ the turbine loba LO400.
On the dyno test i have run only 351 Hp and 522 Nm (see attacched photo)
for have this power i have this pressure turbo:
turbo pressure Peak : 2 bar
turbo pressure at 6.000 rpm : 1.45 bar
turbo pressure at 7.2000 (limiter) : 1.25 bar
I ask those who have this turbo if you can tell me if it turns more 'or less in these pressure or if pressure turns to more' high and has 400 hp rolled those that sell this turbine
I repeat my car is a stage 2+ with this upgrade : exhaust complete ; big intercooler ; WG forge ; induction kit with cone ; Autotech fuel pump.
thanks in advice and sorry for my bad english ![]()
at the begginning was this
I do not like to view the chassis metal black and i prefear with the lower seat.
Rear seat delete ![]()
external upgrade...
unit electronics is evolving to make more 'hp and hope to get at least 380hp
other upgrade mouted yesterday:
ST XTA suspension are mounted ; Today I set the various heights front and rear axle.
Stay tuned
