Haldex Performance.
  • I'm Gone.
  • 7. Februar 2010 um 11:07
  • I'm Gone.
    We are now able to offer a new type of switching system for the Gen II Haldex (example, MKV R32) and Gen IV system( example, TT RS).
    The system uses a module that plugs into the controller. Then rather than having the regular mechanical switch in the cabin installed, you simply have a key fob remote which allows you to select your desired mode.
    The module sits neatly in the boot under the load liner.
    Like the mechanical switch, this remote switch must be fitted with a Performance Haldex controller available separately, also now availble for the TT RS.
    Fernbedienung für HPP Gen 2 (MKV R32) + Gen 4 (TT RS)
    Artikel Nr: EL 00 00 068
    - Anschlussbox
    - Fernbedienung
    • 2. März 2010 um 18:52
    Hab schon davon gehört. Soll auf Dauer die Haldex zu stark beanspruchen weil die nicht dafür ausgelegt ist.
