/Aftermarket/MTM/003.jpg)
SPECIFICATIONS: MTM TTS 2.0T S-TRONIC
Engine:2.0 TFSI quattro
Displacement in cc: 1984 ccm
Bore & Stroke in mm: 82,5 x 92,8 mm
Compression: 9,8 : 1
Boost Pressure (max.): 1,55 bar
Gearbox Type: 6-Speed S tronic Direct-Shift
Power Output (max.): 243 kW (330 bhp) at 6240 rpm
Torque (max.): 420 Nm at 3200 rpm
Top Speed in km/h: 265 km/h - Depends on Tire Size
Drive Type: quattro All-wheel Drive
Brake System: front 380 x 34 mm Drilled, 8-piston Brembo-Caliper
Tires: Michelin Pilot Sport PS2 245/30 ZR 20
Wheels: MTM bimoto forged rims 9 x 20"
Jarod.
